new project.
  • papabuell
    • 03.06.2023
    • 15
    new project.
    Hello, I'm Frank from Belgium and I have a problem.
    I am currently playing with the casablancas and they are playing great, just not in the new home.
    Here I miss the low part, adjusting the space is not possible.
    So the only solution is to build a new speaker that gives more bass.
    Found a few contenders among the Visaton designs, namely the Atlas mk2-Concorde 2 and the Solitude.
    What are your thoughts on this or do you have any other suggestions.
    The speakers must still be around 90 db efficiency since I play with a luxman 590 classA of 30 watts.
    Thanks for the answers.
  • Kay*
    • 13.11.2002
    • 945
    that's maybe the first problem
    refer
    https://www.hunecke.de/en/knowledge/...ics/index.html
    best regards
    Kay
      • 28830
      A new speaker is NOT the solution. It's speaker and listening-position. Can you give us information about this, esp. room-size?
      • Markus213
        • 11.03.2017
        • 886
        Ich würde die Casablanca umbauen. In das untere Teil würde ich einen TIW300 einbauen, natürlich die 10cm Verbindung verschließen. Den Oberteil als Satellit ab 200Hz, den unteren als BR laufen lassen.
        • Hiege
          • 14.03.2008
          • 999
          Huhu
          If you have an Android Smartphone, you can use pink noise and the app spectroid for a First Check.
          And please check - +
          I also think another speaker is not the best solution.
          ​​​​​​The wall material in your listening room is also important.
          Greets
          Ich glaube mit dem Englisch lasse ich das besser
            • 28830
            Atlas 2 and Concorde 2 are the old models, Atlas 5 and Concode 3 or Concorde WG (much better) are the new ones.
            May be, an aktive subwoofer will solve your problems, because you can position it on the (acoustic) best place.
            Zuletzt geändert von walwal; 06.06.2023, 12:06.
            • papabuell
              • 03.06.2023
              • 15
              The space is 6.5 mt wide and 5.4 mt deep, ceiling 2.8 mt high.
              A sub may not be placed (from the woman) nor absorption panels so I'm stuck there.
              My sitting position is about 4 mt from the center of the setup.
              • papabuell
                • 03.06.2023
                • 15
                Y dont find info about the concorde WG.
                  • 28830
                  https://forum.visaton.de/forum/neue-...-mit-waveguide
                  • Lebrichon
                    • 20.06.2008
                    • 292
                    If the speakers are connected correctly and the bass response is still not okay, I guess it is a typical room acoustic problem, which Kay* and walwal already mentioned.
                    I've made a small sketch of your room:
Name: Listening position.png
Ansichten: 725
Größe: 36,9 KB
                    Could you please confirm the position of the speakers and your listening position in this sketch? Perhaps your listening position is in an area, where the bass response is very low because of standing waves.
                    By the way: With the following online tool https://www.hunecke.de/en/calculators/loudspeakers.html you can calculate the room and its response to different loudspeakers. It can help to understand your problem, even if exactly your speakers are not included in their list.
                      • 28830
                      I was eager....that looks real bad. Just a guess, no exakt positions. But there is hope: move the speakers to the backwall and there ist no leak of bass anymore.
                      Klicke auf die Grafik für eine vergrößerte Ansicht  Name: bassloch.jpg Ansichten: 0 Größe: 40,0 KB ID: 711860
                      • papabuell
                        • 03.06.2023
                        • 15
Ansichten: 725
Größe: 36,9 KB
                        The speakers are 135 cm from the side wall and 20 cm from the back wall.
                        Between the speakers are 2 column cabinets and a low cabinet with the installation.
                        Have already had measurements done and we saw a decent dip below 100hz.
                        The solution was bass traps and acoustic panels behind the speakers and on the opposite wall.
                        But this is unfortunately not allowed by the woman.
                        So we have to look for other solutions.
                        The only thing I can think of are speakers that give more bass.
                        • papabuell
                          • 03.06.2023
                          • 15
Ansichten: 725
Größe: 36,9 KB
                          We tried to close the bass ports at the front and mount a large one at the rear, but the result was disappointing.
                          • Kay*
                            • 13.11.2002
                            • 945
                            Frank,
                            do you tried closing the bass ports complete too?
                            it's possible to show your measurement?
                            best regards
                            Kay
                              • 28830
                              If the speakers are connected correctly...
                              Are they? Please check with a listening test.
                              https://www.audiocheck.net/audiotests_polaritycheck.php
