TIW400 Dipol Sub
  • Eddie
    • 25.06.2011
    • 524
    Zitat von agossi
    gibt es eigentlich beim RiPol eine Vorder- und Rückseite
    Wenn ich hier nach gehe http://www.lautsprechershop.de/hifi/ridtahler.htm, dann ist die Öffnung mit den Membranvorderseiten vorne. Aber das ist wohl Geschmacksache.
    Eddie
      • 29030
      Bach. Toccata und Fuge von Telarc
      Tschaikowski 1812 von Telarc. 10 Hz Kanonenschüsse. Die waren das Ende meiner (30er) Passivmembranen in den alten Boxen. Naja, die Schaumstoffsicke war mürbe.
      Daaas geht tief.
      Foreword on Fireworks Sound File
      Well it is probably no surprise to you that I have a fondness for low frequencies and loud noises. If you have heard our speakers, I would like to think maybe its not a surprise that I am keenly interested in reproducing the "stereo image" and realism in reproduction too.
      I have been developing a microphone invention for a while now and on the 4th of July, I was inspired to set it up in the back yard at my house to record the Town's fireworks which are set off about ½ mile away.
      I put the last few minutes of it on a CD and have since played it (to be honest, over and over). It was so much fun, I thought others might want to play this too.
      A word of warning.
      This recording has a HUGE dynamic range of about 70dB and a peak to average ratio of 40 dB. On the peaks, it is easy to clip things and the spectrum is such that the level at 10Hz is about equal with that at 50Hz (a broad mound around 25 - 30Hz).
      In other words, this recording can gobble up all the headroom you have and the source is one of the most difficult things to reproduce there is from many aspects. Preserving time and bandwidth critical so also try it on good headphones if your not impressed with it through your speakers.
      Anyway, take the file and burn it on to a CD (make a couple copies one after the other) and have fun and approach maximum level carefully.
      Best Regards,
      Tom Danley
      • the.Sandmann
        • 18.02.2011
        • 579
        Lustig,
        ich hatte gerade zwei Züge, eine Harley und ein Feuerwerk in meinem Wohnzimmer, ich
        wusste gar nicht, dass da soooo viel Platz drinnen ist.
        Beim vorbeifahrenden Zug habe ich lediglich den Fahrtwind vermisst, die Bodenschwingungen waren da.
        Der startende Zug hat aber ziemlich fiese Nebengeräusche.
        Alexander
        • HCW
          HCW
          • 05.01.2005
          • 1865
          Von der CD?
          LP macht ja sogar enstellige Hertz, sogar ohne Musik, und mit recht ordentlichem Pegel wenn man nicht filtert.
          Gruß, H.-C
            • 29030
            Das mit LP kenne ich noch. Rumpelfilter.
            Bei der CD habe ich unterschiedliche Angaben zur unteren Grenzfrequenz gefunden. Manche geben 20 Hz an, andere halten 1 Hz für möglich. Jedenfalls ist das sehr Hubintensiv.
            Bei Musik brauche ich das nicht, da wären meine Al 200 überfordert, deswegen Subsonic bei 33 Hz gesetzt. Die 29 Hz (Raum) bringen immer noch den Sessel zum Wackeln.
              • 2905
              Warum sollten bei einer CD keine einstelligen Hz-Werte möglich sein?
                • 29030
                Das frage ich mich auch. Die 16 bit begrenzen ja nur die Frequenz nach oben. Vermutlich kommen die 20 Hz von der Standard-Hörgrenze 20 Hz. Dass es auch "Verrückte" gibt, die 8 oder 16 Hz hören/fühlen wollen, war unvorstellbar.
                • Masuuk
                  • 24.11.2009
                  • 657
                  Die Frage ist wieviel Hz die Koppelkondensatoren in der Aufnahmetechnik abschneide und ob die Ausgangsstufe des CD-Players oder der Endstufe das können. So gesehen wäre es Platzverschwendung auf der CD wenn man es nicht reproduzieren kann.
                  • Mr.E
                    • 02.10.2002
                    • 5437
                    Das machen die 44,1kHz.
                    • Sly
                      Sly
                      • 10.01.2010
                      • 187
                      Hier gehts bis 5Hz runter
                        • 29030
                        Ich bin zwar kein Kupferwurm, aber bit und Maximalfrequenz hängen doch zusammen?
                        • andi_m
                          • 26.09.2004
                          • 1435
                          Hallo Walwal
                          Die Bits bestimmen nur die Dynamik. Die Grenzfrequenz wird durch die Abtastrate bestimmt.
                          Der Sub ist sehr gelungen.
                          Gruss Andi:m
                          dabei sein ist alles
                          (Zitat: Jürgen von der Lippe)
                            • 29030
                            Danke für die Info.
                            • Masuuk
                              • 24.11.2009
                              • 657
                              hmm?
                              Die Bits bestimmen die Abstufung der Spannungspunkte (MaxSignalpegel/2^(16)) die 44KHz resultieren aus den Gesetz von Nyquist-Shannon-Abtasttheorem (Doppelte oder größere Abtastrate als Nutzsignal für eine korrekte Rekonstruktion des Signals).
                              • andi_m
                                • 26.09.2004
                                • 1435
                                genau so
                                16 Bit ca. 65000 Stufen
                                24 Bit ca. 16700000 Stufen
                                32 Bit ca. 4300000000 Stufen
                                Frage mich immer noch warum bei der CD nicht auf 24 Bit gesetzt wurde
                                Gruss Andi_m
