It will be corrected in the next version.
Visaton open baffle project idea, opinions?
This is a bug in Boxsim 2.0. Best workaround is what jama already did. He used a newer driver file. This bug happens to all drivers that are measured on the wide side of the old test box.But I had a little problem with the woofer settings, when I set the "Volume increase factor" to 1, the woofer response jumped to the top of the chart. When it changed it to 0.0000001, it seemed to work. I hope this does not make the results invalid.
It will be corrected in the next version. -
whit SC13 or WS-13EEinen Kommentar schreiben:
hi dave, sorry i speak french or german
I have simplified the filter
for a modest budget take the excellent and low budget SC13 instead of the AL130Einen Kommentar schreiben:
Hello From Canada!
Sorry, I don't speak German, but I came here for the Visaton Expertise!
I am looking to make an all Visaton open baffle speaker with a maximum width of 38cm and maximum height of 120cm.
The budget is to be modest using a pair of inexpensive high QTS WS25E-8 10" woofers, an AL130M-8 for the important midrange and the G20SC for a tweeter with good off axis response.
I have attached a few graphics and the .BPJ file if anyone wants to look at it.
I followed the open baffle instructions for Boxsim at,
What do you think?Angehängte Dateien- visaton open baffle july 16 freq response.jpg (61,3 KB, 475x aufgerufen)
- visaton open baffle july 16 crossover.jpg (58,1 KB, 439x aufgerufen)
- visaton open baffle july 16 box layout.jpg (45,9 KB, 468x aufgerufen)
- problem with open baffle instructions.jpg (74,9 KB, 457x aufgerufen)
- oppen bafffle july 15 parts started WS25E8 woof mid good working on mid to tweeter working on h.BPJ (109,5 KB, 380x aufgerufen)
Stichworte: -
