Use premium-grade FETs and diaphragms for high sensitivity and superior signal-to-noise ratio. Each
microphone features GSM buzz-blocking capacitors. Upgrade the ECM microphone that you use today with a PUI Audio HD Series microphone. The 9,7mm diameter AOM-5024L-HD-R is designed for extreme fidelity in even the quietest settings from 20 Hz to 20 kHz.
* also nicht getestet.
Interessant ist der extrem gute SNR (wenn's den stimmt)
