[English] I search filter for SC10N and W130S
  • Benny
    • 01.04.2002
    • 1622
    If you're planning a sub/sat- system, there's no recommendation for <<bass>> on the fronts (and especially the center)...
    I've made some thoughts and wrote them down on my website (here in the german section)...
    Maybe you should have a look...
    I've tried to write in easy sentences, so that a translation with f. x. Babelfish should give propper results...
    (Perhaps I should translate it by myself in an upcomming update)
    MfG B.
    • CCJENS
      • 16.08.2004
      • 21
      i know that, but i want some bass out it
      Is the Visaton genesis sat, does it have some bass or not?
      • CCJENS
        • 16.08.2004
        • 21
        Help me out with a cool design, and i want some bass from the rears, because now i dont have bass!!!
        80 = budget, sizes are same as 3 posts ago..
        • Benny
          • 01.04.2002
          • 1622
          No.
          Taken from the description
          The tuning frequency cuts in at 110 Hz.
          If your budget is 80 €, it's a good start to build the subwoofer, I've linked, first.
          That is about 60 € (without sub- amp)...
          Lateron, you can start to collect speakers one by one, even when the money allows it, you buy the parts...
          MfG B.
          • CCJENS
            • 16.08.2004
            • 21
            I dont wanna build a subwoofer now :-), first the speakers then the subwoofer :-)
              • 21.09.2001
              • 4774
              you want a cheap, small, but good speaker? Look at the 'Aria Ultralight' filter diagram above.
              I build a pair for my mother to christmas, they looks so:
              more about, but in german: http://woofa.abi05.info/selbstbau/ar...ultralight.htm
              a little bass it can reproduce, but remember the size. Small speakers don't have really bass.
              Cheap, good and with pretty good bass:
              more about in german: http://woofa.abi05.info/selbstbau/ku...eschallung.htm
              Filter: look for the 'Alto I / II' filter, an replace the 8,2 Ohms resistor in series to the Tweeter with a 3,3Ohms resistor. Sounds good, and can reproduce bass you can feel, but you can't buildt it smaller than 20-25 Litres.
              • CCJENS
                • 16.08.2004
                • 21
                Hmm, yes nice the Aria Ultra Light...
                What are the sizes?? i want some bass, not much!!. because there will be a subwoofer..
                I am looking @ this now:
                Monocar...
                SPH-100AL, DT-107, Visaton HW2/70NG-8 filter,
                good for the tweeter 3,000hz Turn-over frequency
                • System Panic
                  • 16.01.2003
                  • 330
                  If you take a woofer, a tweeter and such a allround crossover like the visaton crossover, your tweeter will not burn and there will be some output. But if you build one of the recommended speakers ( see my mail, then check prices on the free market and if the budget is very tight on ebay ) you will get a speaker that also sounds good, most likely better than a speaker you can buy for that price.
                  And if one day you want more power and more bass, you can build a subwoofer.
                  • CCJENS
                    • 16.08.2004
                    • 21
                    Yes, the mini monitor is too large :-(.. :S
                    But is the combination good? for the monacor?
                      • 21.09.2001
                      • 4774
                      Solo the Aria Ultralight makes some bass. Will be best in combination with a subwoofer.
                      • CCJENS
                        • 16.08.2004
                        • 21
                        Sizes??
                        • ichse1
                          • 22.05.2002
                          • 1514
                          Like this, but the other tweeter (SC10N) needs an other hole-diameter.
                          regards Stefan
                          mfg Stefan
                          • CCJENS
                            • 16.08.2004
                            • 21
                            Aight,
                            I am building the Mini-Monitor now :-) but then a smaller version 8l BR..
                            But i got a question, WinISD is saying that i need to use a 0,47 vent diameter , the lenght must be 16,21cm!
                            Aight, now i am taking and reading from the Hobby-Hifi mini-monitor, they use 50mm and the lenght is 11CM..
                            But WinISD says:
                            12,72 as lenght..
                            But why the magazine says 11cm?
                            Now i can get a Visaton -BR19.24 but with the 8l is must be 27,88 lenght ??
                            I can get a 50mm vent diameter and a lenght of 14,5CM, but WinISD says i need 18,75???
                            Pls help me out..
                            The speaker rules @ 8 L
                            And whats better to use?
                            Pritex of Sheepwol or Polyster?
                            Magazine says polyester..
