[English] I search filter for SC10N and W130S
  • CCJENS
    • 17.08.2004
    • 21
    Hello,
    I am searching a filter grafik for sc10n and the w130s
    they are gonna play in a 10liter box..
    Closed, so no bassreflex...
    They will be used as rear and fronts,
    Does somebody have a filter grafik/schema/design for me?
  • Benny
    • 02.04.2002
    • 1622
    Maybe you could use this one (note, that the W100S is used)
    It should give a good base for experimenting, although the Aria only has 3.8 l...
    MfG B.
    • CCJENS
      • 17.08.2004
      • 21
      Whats the difference??? about the 100 and the 130..
      • Benny
        • 02.04.2002
        • 1622
        Voice coil inductivity, frequency range, Qts, Qes, Qms, box volume...?
        Is there a reason, why they are going to play in 10 l? If you search for "Aria Ultralight" in the "Gallery of projects", you'll find a thread by MrWoofa...
        He has build them, and maybe someone translates the essential comments about this project for you.
        MfG B.
        • System Panic
          • 17.01.2003
          • 330
          One of the german homebrew magazines had a speaker with these chassis, it was called " mini monitor ".
          This is nearly what you are asking for. Nearly, because it is no closed box..
          see http://www.visaton-bausaetze.de/hifi/minmon_basic.htm
          • Benny
            • 02.04.2002
            • 1622
            That is a good tip, but I can't see any xover schematic in that link, and CCJENS asked especially...
            MfG B.
            • CCJENS
              • 17.08.2004
              • 21
              I am building a small speaker, with a small budget, but with quality.. so thats why there are 10 liter, only for the smallnest..
              Ok, i saw the link of the Mini Monitor, but no filterdesgin :-(
              • CCJENS
                • 17.08.2004
                • 21
                Just got a e-mail from a dutch company,
                He says that for this combination you need to youse the
                Visaton HW2/70NG-8
                http://www.bmm-electronics.nl/Produc...roduct_ID=1940
                What to do?
                • System Panic
                  • 17.01.2003
                  • 330
                  The crossover and the newspaper article are under copyright.. thats the problem..
                  • ichse1
                    • 23.05.2002
                    • 1514
                    I think short quotations are allowed, but I don't have the right HH here. Sorry!
                    regards Stefan
                    PS: Don't use the Visaton HW2/70NG-8
                    mfg Stefan
                    • CCJENS
                      • 17.08.2004
                      • 21
                      regards Stefan
                      Why not?
                      • ichse1
                        • 23.05.2002
                        • 1514
                        To get a good result, a crossover has to be fitted exactly to the used drivers and housing.
                        The crossover you mentioned is a "one for all" version.
                        regards
                        PS:sorry for the bad english
                        mfg Stefan
                        • CCJENS
                          • 17.08.2004
                          • 21
                          Ok, i got a problem my budget can't take this..
                          Now i am looking at
                          Alto Genesis Sat and the Alto 1, alto 1 is to big
                          But the genesis sat is perfect!! , width, height etc..
                          But are these on good? will they have some bass?
                          • Benny
                            • 02.04.2002
                            • 1622
                            <<Will they have some bass?>>
                            Certainly not, because they are too small and only with the W100S...
                            Why not "Alto1"?
                            This link leads you to the modification with the G20SC, which is approved several times.
                            This modification is highly recommended, because the DT94 isn't wellsounding and no more "state of the art"...
                            And if you want to have some bass, you could build a cheap subwoofer like this one...
                            That's a good set to start with if you are a newbie into speaker- DIY...
                            MfG B.
                            • CCJENS
                              • 17.08.2004
                              • 21
                              well i got now a jbl scs 138 system,
                              I need to know, do they have some bass?, because the jbl 138 sats, doesnt have any bass!!
                              I will build a subwoofer, it gonna be a 5.1 system, that i gonna build, and i want some bass, not only the subwoofer, but the rear/fronts/center too..
                              And if you got some idea's for max 80 EUR!
                              I need a monitor speaker (h/b/t) 25 - 28 cm x 20cm x 20 - 25cm
                              Do you have something 4 me pls?, or any options to use..
                              Nobody with a cool 2 way system that are not to big ?:P
                              How much does the Aria ultra light cost?
                              How is the bass? better then JBL SCS 138 sats?
                              Watts??
