I'm looking for a wellproofed enclosure for W200S. Does anyone have "the wright concept" ? I want the basses to sound deep, dry and 'under control'. I'm not sure it will sound good in a bassreflex (like the 'Startlet')
All of your reactions are welcome!
the programm is really nice and brings good results
I would always put a W type woofer in a closed cabinet
(got two W300S running here (closed box) but didn't have the time for excessive testing, but I think, they sound great)
I've been trying both: BR an closed box.
after hearing the W200S in a CB with an active Bass boost I'm through with BR!
I think 20-30l with a bassboost of about +6dB at 30Hz will sound very reasonable.
but if you don't have the opportunity to equalize active, check out the W20.39.
greetz
Che
Alle Datenpakete sind gleich,
aber manche sind gleicher.
As you might have guessed: my experiment with the W300NG extra has failed. They interferred with the W200S way to much. It went totally out of control. I think due to faseproblems. They just can't keep up with the speed of the W200S (I knew this could be a problem but didn't think it would be a BIG problem). Anyway; I'm now more confinced I should stick to a sealed enclosure.
I want to use it in a 'normal' stereoset, not for homecinema, not as a subwoofer. I'll use them up to 1500Hz, then the DSM38FFL will take it over up to 7000Hz and the DTW97 will 'finish it off' .Apart from that: the W300NG just doesn't have the quality the W200S has. I think I will use them later in a 'partybox', together with some 'leftover' speakers I still have somewhere.
Does this answer your question?
just test something with boxsim, it has all the visaton chassis inside
you could make a cabinet with bassreflex and test it
if you don't like it, just close the bassreflex-hole and you have a closed box
the size would be ok because bassreflex boxes are always bigger than closed ones
and a bit extra volume is never wrong
I have made a plan now to build an enclosure of about 50 liters with the possibility to change the volume without to much trouble. With and without a BRport. It will take some time but it will be fun too! I'll let you know what the results are...
