Visaton Couplet Standbox
  • sturkku
    • 15.03.2014
    • 2
    Hi all,
    Sorry for posting this in English, I don't speak German at all.
    I have a Visaton Couplet speaker kit, and now I'm wondering whether to build it as a shelf-speaker or as a standbox-version. The problem is that I really can't find much information about the standbox-version. I know that it can be found in Hobby Hifi 5/2000, but that article is out of my reach.
    Some of the questions I'm wondering about are as follows: What are the advantages or disadvantages of the standbox over the shelf-version? Does the standbox require a different crossover? Is it possible to find plans for the standbox? Or does someone have a copy of the Hobby Hifi article (maybe I can understand it with Google Translate)? Any other information I should know of?
    By the way, another thing I'm wondering is that should one have a subwoofer with the Couplet speakers?
    Any help and opinions are greatly appreciated.
    Regards,
    Sturkku
  • Pansen
    • 12.04.2009
    • 1495
    First, sorry for my bad english.
    Is your question about Couplet Standbox without waveguide? If so, the only advantage i can see is about optical reasons. As you can see in my threads (search for it), i've built a Couplet Standbox with Waveguide - you can built it for a shelf as well. There are no disadvantages for the different versions.
      • 28924
      Hi sturkku
      You can order HH 05/2000 here:
      But you can also use the original Couplet crossover. Volume for each TMT is 15 L with BR 19.24. BxHxT 200x1100x300. The Crossover-compartment at the bottom ist sand-filled, H=300.
      The use of a subwoofer depends on the hearing level.
      Pansen mentioned Couplet with Waveguide, this Speaker ist much better.
      Regards Jürgen
      • sturkku
        • 15.03.2014
        • 2
        Thank you Pansen and walwal for your information.
        I meant Couplet without waveguide, as I was not aware of any waveguides. (I am a real beginner.) Now I got interested about the waveguide also. I tried and still will try to search for your threads Pansen, but it is quite difficult as I speak zero German.
        Which waveguide did you use Pansen?
        I will order the article. Does it include plans for the standbox cabinet?
        Regards,
        Sturkku
          • 28924
          More about Couplet WG:
          This is not an official Kit, the crossover must built by yourself.
          Waveguide is made by Visaton WG 148 R.
          Sturkku, you got PN (Private Nachrichten)
          Zuletzt geändert von walwal; 15.03.2014, 17:41.
          • seewolf
            • 02.04.2010
            • 98
            Hi sturkku!
            Try it here:
            boxenwastel.lenz-online.org
            best regards
            Werner
