Messungen belegen das Gegenteil.
As a test, I checked a few caps in my workshop. I could not measure any distortion created by an electrolytic passing signal current (as opposed to speaker current, which I did not test at this stage). I also checked the frequency response of a couple of electros, and found zero degradation at 100kHz - even a square wave was passed with no visible deterioriation in rise time (which would indicate frequency limitation).
..... None of these devices introduced any measurable distortion or anything else that I could see. One thing I know for sure is that if I can't see any change on my distortion meter residual, then there is no change. A complex waveform does not affect the validity of this testing, since I can test distortion at any frequency I like, and the appearance of multiple frequencies at once does not affect any passive device.
Für denjenigen der 100ztel nicht hört ist es eh wurscht.
Die übliche Schutzbehauptung: "ich höre es aber". Und "Deine Anlage/Gehör taugt nichts".
hören
