ARTA 1.9.4 ist online
    • 29.09.2000
    • 4539
    Die neue ARTA Version 1.9.4 ist seit 30.06.2021 online: https://www.artalabs.hr/download.htm
    • 2905
    Danke für die Info!
    Zitat von Arta-Homepage
    Changes from version 1.9.3 are:
    - ARTA Step response is now obtained by cumulative integrating IR after the cursor position (if cursor position < IR maximum positiom)
    - Smoothed FR overlays can be exported in textual files
    - Sine burst duration can be generated in multiple of half sine periods.
    - Corrected bug in File->Export in CSV in FR1 window
    - Microphone calibration can be enabled even if input signal level is bellow -60dB.
    - STI module is implemented according to new standard IEC 60268-16:2020 Ed.5
    - STI module can import predefined noise SPL from textual files
    - Multione signals can be user defined with tone density from 3 to 12 tones per octave.
    - User defined filter can be applied to multitone signal (IEC 660268-16 and CTA-1034A)
    - Spectrum overlay level shift when using FR compensation is resolved.
    - Generation of square and triangle signals in wav file is improved
    - ARTA file version information corrected for "Load and sum" and "Directivity pattern creation" functions.
    - ARTA can have arbitrary number of fixed overlays in FR1, FR2, Spectrum real-time modes
    - Fixed overlay can be generated in Octave smooting and Octave bands modes.
    - STEPS allows FR compensation to be applied to loaded FR data
    - STEPS scalling dialog improved
    - STEPS Linearity module accept all sampling frequencies, not only 48kHz
    - STEPS saves which distortion to plot and current plots margins in Registry
    - LIMP saves graph margins in Registry
    - LIMP gets Overlay menu item for making target impedance curve calculated from measured loudspeaker parameters
    • ente
      • 02.02.2004
      • 564
      ... und nun auch noch ein kleines Service-Release 1.9.4.1.
      In Wesentlichen wurde im SPA-Mode die Multitonanregung optimiert.
      Heinrich
      • ente
        • 02.02.2004
        • 564
        Seit heute steht ARTA 1.9.5 auf der Homepage von Ivo zum Download bereit.
        ARTA Download and Order (artalabs.hr)
        Änderungen gegenüber Version 1.9.4.1 sind:
        - Multitone generation algorithm improved.
        - THD+N frequency weighting switch updated.
        - Improved calculation of Directivity Index. Now user chooses type of spatial directivity pattern used for DI calculation: cylindrical or axe-symetric spherical.
        - Spherical pattern is used as defined in standard IEC 60268-21.
        - Directivity index can be estimated for free full space and half-space radiation
        Viel Spaß
        Heinrich
          • 29012
          Etwas Werbung für Multiton-Messung.
          https://forum.visaton.de/forum/messt...zerrungen-demo
          Beispiel (ob das Arta ist, weiß ich nicht). Zwei LS (ohne Bass) Rot = sehr gut, Grün deutlich schlechter.
Ansichten: 887
Größe: 41,4 KB
          Zuletzt geändert von walwal; 20.09.2022, 11:03.
          • ente
            • 02.02.2004
            • 564
            Rechtzeitig zu Weihnachten wird ARTA 1.9.7 erscheinen. Folgende Änderungen/Erweiterungen sind enthalten:
            1. In ARTA sind alle Signalpuffer zur Messung der Impulsantwort auf 512 MB vergrößert. Dies ermöglicht die Messung von Nachhallzeiten von mehr als 12 Sekunden. Die Verwendung größerer Puffer führt nicht immer zu besseren Ergebnissen. Als Faustregel empfiehlt es sich, eine Sequenzdauer zu verwenden, die gerade größer als die Nachhallzeit ist.
            2. In ARTA kann der Benutzer jetzt die Signalerfassung verzögern, was wichtig ist, wenn sich die Abtastrate ändert. Diese Verzögerungszeit nennen wir Laufzeit für die Änderung der Abtastrate. Für kostengünstige USB-Soundkarten könnte sie ziemlich groß sein und sie kann im Audiogeräte-Setup von 0 bis 2500 ms angepasst werden. Hochwertige Soundkarten (wie RME) benötigen diese Laufzeitanpassung nicht.
            3. PIR-Dateien, die zur gleichzeitigen Messung von Impulsantwort und Verzerrung mit ARTA-Version 1.9.5 (oder früher) aufgezeichnet wurden, waren nicht mit Version 1.9.6 kompatibel. In dieser Version ermöglichen wir dem Benutzer einer älteren Version (die eine gewobbelte Sinus-Erregung von 10 Hz verwendet) oder eine neuere Version (die eine gewobbelte Sinus-Erregung von 5 Hz verwendet) zu bestimmen.
            4. Der maximale Pegel des Sinus-Burst-Signals ist auf -1 dBFS eingestellt.
            5. Für den Import/Export von Impulsantworten und Signalaufzeichnungen sind neue Menüpunkte definiert.
            6. In LIMP wurde die Messung von R-, L- und C-Elementen erweitert. Hinzugefügt wurde ein Bericht für Verlust- und Qualitätsfaktoren.
            7. Einige CSV-Exportfunktionen wurden verbessert.
            8. In ARTA ermöglicht ein neuer Spectrum-Overlay-Menüpunkt das Speichern von Multiton- und Verzerrungsergebnissen in separaten Textdateien.
            9. Diese Version funktioniert nicht mehr unter Windows XP
            Ad 1) Damit sind auch Sinus-Sweeps bis 12 sec Dauer möglich
            Ad 2) Bessere Anpassung von günstigen Soundkarten
            Ad 8) Damit ist die MultiSine-Messung komplettiert. Jetzt sind MultiSine-Messungen mit beliebiger Filterung exportierbar und beliebig auswertbar.
            Heinrich
              • 29.09.2000
              • 4539
              Super, Dankschön für die Info!
