G.R. Slone, Audiophile's Project Sourcebook
Dieses Thema ist geschlossen.
  • raphael
    • 09.05.2001
    • 3491
    Der Verlag über das Buch
    Build audio projects that produce great sound for far less than they cost in the store, with audio hobbyists' favorite writer Randy Slone. In "The Audiophile's Project Sourcebook", Slone gives you: clear, illustrated schematics and instructions for high-quality, high-power electronic audio components that you can build at home; carefully constructed designs for virtually all standard high-end audio projects, backed by an author who answers his email; 8 power-amp designs that suit virtually any need; instructions for making your own inexpensive testing equipment; comprehensible explanations of the electronics at work in the projects you want to construct, spiced with humor and insight into the electronics hobbyist's process; and complete parts lists."The Audiophile's Project Sourcebook" is devoid of the hype, superstition, myths, and expensive fanaticism often associated with 'high-end' audio systems. It provides straightforward help in building and understanding top quality audio electronic projects that are based on solid science and produce fantastic sound!
    - Balanced input driver/receiver circuits
    - Signal conditioning techniques
    - Voltage amplifiers
    - Preamps for home and stage
    - Tone controls
    - Passive and active filters
    - Parametric filters
    - Graphic equalizers
    - Bi-amping and tri-amping filters
    - Headphone amplifiers
    - Power amplifiers
    - Speaker protection systems
    - Clip detection circuits
    - Power supplies
    - Delay circuits
    - Level indicators
    - Homemade test equipment
