I’m building a pair of ARIA KE’s, these are going to play together with two subs (highest variable low pass 120 Hz). I’ve added a high pass filter ( 100 Hz) to the filter of the aria’s so the sub has to do the heavy work
I prefer closed cabinets and I want to make them closed.
Now my questions are:
What is the recommended volume for a closed cabinet aria (what would you suggest)?
Should I stuff this volume with damping material?
Is it bad that these subs are downfiring? (I heared that it’s hard to locate sound under 120 Hz?!)
Do I have to change the filter if I’m making a closed cabinet and the filter is designed for a bass reflex -housing? (maybe a stupid question but I have to be sure)
And at last, is there enough “midbass” (100-300 Hz) from the TI 100 to sound well?
Greetings
alexander
