Xover suggestion
  • mr_push_pull
    • 06.07.2004
    • 39
    Xover suggestion
    Could someone suggest an x-over for the combination W170S/4Ohm with G20SS/8Ohm? I have toyed with XOverSim and the published Visaton specs and I arrived to a 3rd order with Zobel for the mid-bass and plain 2nd order for the tweeter without impedance correction, but I'm not shure wether to go with this combination. Any advice?
  • Tosti
    • 21.10.2002
    • 846
    there exists already a developed crossover for this combination. Look out for the "Morion" by HobbyHifi. You'll find one in the gallery.
    Greets
    Tosti
    • ichse1
      • 23.05.2002
      • 1514
      The HH Morion uses the W170S 8ohm! So the crossover cannot be used for this setup.
      Use the search function for "Alto G" .
      mfg Stefan
      • Tosti
        • 21.10.2002
        • 846
        @ichse1:
        oups, sorry Well, at least it's a W170
        • Round1
          • 18.04.2001
          • 84
          Moin mr_push_pull,
          Visaton offerd a cheap upgrade for the Alto Series => socalled Alto G Series. At first they used the G20FFL. This Tweeter is not supported any more. You can use the better G20SC without any change on the Xover.
          At www.speaker-online.de you will find the schematics. You will find them behind the last link in the category (left side) "Bauvorschläge".
          I hope I could help you.
          Gruss AS 8-)
          • mr_push_pull
            • 06.07.2004
            • 39
            Thanks guys, I was just about to make the mistake of taking the filter from Morion, without noticing that it is designed for W170S/8Ohm. OK, I'll look at the filter for Alto G, I gave up the idea of trying to design my own, it's a nightmare. Thanks again.
            • Benny
              • 02.04.2002
              • 1622
              You'll find the xover in "our" board too...
              Try and have a look here: http://www.visaton.de/vb/showthread....&threadid=6973
              Sorry Round1...
              MfG B.
              • mr_push_pull
                • 06.07.2004
                • 39
                I looked on the forum too. Thanks, that's exactly what I needed.
                • mr_push_pull
                  • 06.07.2004
                  • 39
                  One thing I noticed with Visaton suggested xovers, they don't generally use impedance correction.
                  For instance I simulated the xover from Alto G in XOverSim and it had a huge impedance rise around 4 KHz...
                  • Benny
                    • 02.04.2002
                    • 1622
                    Where's the problem?
                    Impedance correction is only necessary when you use tube amps.
                    Chip amps don't really have a problem with impedances which are not corrected...
                    MfG B.
                    • mr_push_pull
                      • 06.07.2004
                      • 39
                      That's not what I've been told. Maybe I don't understand the concept correctly, but there are a great many people that emphasize the importance of impedance equalization even with solid state.
                      • Round1
                        • 18.04.2001
                        • 84
                        Moin,
                        Yes, your right, impedance equalisation could improve some speaker systems, but please remeber that you are interested in one of the cheapest speakers.
                        The usage of the G20SC Tweeter gives the posibility for a usefull upgrade of the alto series which was designed for beginners and people with a small budget. In most cases these costomers are interested in saving money, so that the price is the most interested fact.
                        If you sum all the costs for such you´re talking about, you would surely get a better speaker from the beginning.
                        If you use a transistor amp with low output impedance you would get surly no advantage of an inpedance equlisation.
                        Gruss AS 8-)
                        • mr_push_pull
                          • 06.07.2004
                          • 39
                          Something like "why bother, it will suck anyway"?
