Room volume
  • Compy
    • 27.04.2004
    • 6
    Room volume
    Hello, sorry but i understand german, but can not write it, so i will do it in englisch, you may write in german.
    My question is, I want to make my home cinema with the Vox 200.
    But now , what kind off volume of the room does this speaker need? my room is 4.30x 4.50 m . The setup would be 3x vox 200 L/C/R , 2x fontana SL/SR and a sub
    Does this setup needs a bigger space ?
  • BigAl
    • 08.02.2001
    • 1257
    Room size is influencing its own resonance frequency and therefore its "boominess" . It has absolutely nothing to do with speaker size but the speakers lower cutoff frequency.
    If problems really occur in your room you still have the option to dampen or fully close the vents.
    Regarding the size of your room, a Vox 200 Setup seems useful to me.
    BTW, welcome to these forums .
    • Compy
      • 27.04.2004
      • 6
      I understand, thanks for the answer.
      When I cover the exhaust off the speaker , can it hurt the speaker itself?
      • BigAl
        • 08.02.2001
        • 1257
        You do not cover the speaker baffle nor its exhaust (just to prevent misunderstandings). What you might take into consideration is blocking the housings vent.
        See the bottom of right drawing.
        This will not damage the speaker at all.
        • Compy
          • 27.04.2004
          • 6
          This was what it wanted to say
          sorry for the ...
          So i can experiment with the speakers
          • BigAl
            • 08.02.2001
            • 1257
            Be my guest .
