Genaudio Intro
  • Genaudio
    • 22.04.2010
    • 1
    Genaudio Intro
    Apologies for starting this new thread, but I do not understand German and I am using google translate all the way to navigate! real nightmare! Please advise if I am in the wrong thread!
    I have just finished a pair of VOX253MTI and Aria 2 MHT Centre. The living room is 7.15x4.40m and all the 7.1 speakers are in "text book" positioning with the right distances and angles, running on a NAD T785.
    I am looking for side and back wall-mount surround DIY options obviously Visaton and to match the kit above. I am not running into the long debated dipole vs bipole vs direct, but being an AV integrator myself I have never heard a dipole that really impressed me. Honestly I prefer a direct radiating sound. Have looked at the Aria Dipol as an option but I'm sure I'll end up with the "direct" switch always on, and would rather modify 4 x Aria 2's to be wall mounted and having more LF output from the 2 Ti's than only 1. Would rather invest in working drivers than 2 HF's doing nothing...........
    Has anyone experienced the Aria Dipol 1 and advise? Any recommendations? Anyone has any other building plans for decent surround options with Visaton drivers?
    BTW I have never experienced Visaton before and built the 253MTI blindly and only heard them once finished .......... now its only Visaton
    Thanks to all.
  • r0b
    r0b
    • 02.12.2005
    • 352
    you should check out the Aria 2 MHT Center, as well as the Aria MHT. If you want to wall mount them, type it all into Boxsim, and check the differences if you set the Baffle to a very big one.
    Although that will be a problem, since both TI100 and the MHT are kind of "unsimulatable", (edit: the TI100 is a challenge to simulate with a small baffle, so with a wall mount it should be better) or at least their real behaviour will be more different from the simulation than others.
    The Aria 2 MHT Center has a 2.5 way configuration, which is good if you want to use it in horizontal config. Maybe you'll get someone who can simulate an Aria 2 wall mounted with a straight 2 way xover. That would probably be the best to suit your Voxes.
    Greets
    Robin
    Zuletzt geändert von r0b; 26.04.2010, 19:17.
