Klirr von Kondensatoren
    • 29067
    Ein link, der viel Geld spart
    2.3 - Distortion Tests Electrolytic Capacitor Test Circuit
    The electro under test was unbiased, and with 5.5V AC at 400Hz across the cap, the distortion rose from 0.02% to 0.022% - a definite increase, but only small. At lower voltages such as 3V open circuit (about 1.6V RMS across the cap), the distortion fell to just over 0.015%. The reason the distortion appeared to fall is simple - the connection shown forms a low pass filter, which helps to remove the harmonics that make up the distortion component of the signal. A first order low pass filter will reduce the third harmonic sufficiently to make reading the difference quite easy. Based on a very similar test done using the simulator, the distortion should be about ½ the generator value, so the cap is still introducing some distortion. As the voltage (across the real capacitor) is reduced, so is distortion, until the noise limit of the distortion meter is reached.
    Attempting the same test described above with a polyester cap was a dismal failure - I was not able to measure the cap's distortion , only the attenuated distortion of the signal generator. As predicted by the simulation, measured distortion was about half that of the generator alone, using a 1uF cap at 400Hz, with 5.5V AC across the cap itself. I am satisfied that the polyester capacitor's contribution to measured distortion was well below my measurement threshold.
  • Ronkel
    • 11.04.2005
    • 142
    Ich frage mich was sogenannte "High-Ender" sagen wurden zu diesem test...
    • Merlin
      • 30.11.2002
      • 837
      sie würden sagen "alles Lüge, dass der 1000 Euro Kondensator besser klingt als die 3 Euro Massenware, höre ich ja schon mit meinen Ohren sofort raus"
