Visatom
  • bambik
    • 08.10.2006
    • 4
    Visatom
    Hi i like to now is ok to use Visatom speakers from web Klamadu for home theatre room, and wich speakers i can use for center chanel .Is don,t neeed to be diy visaton speakers cood be B&w ,Paradigm ,nht esc......
    THANKS
  • Diablo
    I think the VisaTom is a rather good speaker
    it was measured by visaton and seems OK
    for the center (and rear) speaker you should preferably use the same chassis (MHT, TI100, AL200 or GF200)
    which means you should preferably use the same box everywhere
    when room is few, then use something build with the same chassis
    as there are few kits with the MHT you could perhaps build Aria(2) which at least have the TI100
