VISATON Waveguide WG 220x150
  • Verrückter
    • 26.04.2006
    • 483
    Zitat von A R Beitrag anzeigen
    tolles Projekt!
    Da ich mich außerstande sehen, so eine Schallwand mit Doppelwaveguide zu bauen: Wo kann man so etwas beziehen?
    bei mir
    Aber billig ist sowas nicht
    Stefan
    • Verrückter
      • 26.04.2006
      • 483
      Zitat von Verrückter Beitrag anzeigen
      bei mir
      Stefan
      Na, da schau her
      Stefan
      • DaveFred
        • 10.05.2019
        • 21
        G25FFL in WG148 or WG220x150 same response?
        Hello,
        Should the response of G25FFL be the same in WG148 as WG220-150?
        The response of the G25FFL in a waveguide looks quite different in Boxsim than it does in the first post here.
        Does the G25FFL in the waveguide really have the huge on axis dip at 15KHz that Boxsim shows?
          • 28568
          Yes, yes.
          I prefere the Ke 25 SC, which ist also not perfect off axix, but sounds great.
          Zuletzt geändert von walwal; 26.07.2019, 06:49.
            And I prefer the DSM25FFL in the Waveguide. For me the best price/performance...
              • 28568
              I agree.
              But if you want a lower separation frequency, take the KE-WG.
              Zuletzt geändert von walwal; 26.07.2019, 11:37.
              • DaveFred
                • 10.05.2019
                • 21
                I happen to have a pair of G25FFL's already, so they are the best/cheapest option. I also have a pair of waveguides.
                How low a frequency at what slope can the G25FFL be crossed at in the WG148R/WG220x150 waveguide?
                I see that the "Studio 1" crosses it at 1600Hz, the "Chess, Kompaktbox in Hobby Hifi 5/2013" uses 2000Hz and the "ViMo Shelf speaker as in K+T 6/2016" crosses it at 1800Hz with the waveguide.
                The "ProBox Shelf speaker as in K+T 2/2019" crosses the G25FFL at 1900Hz and the "ProBox 6 dB Shelf speaker as in K+T 2/2019" crosses it at 1800Hz without a waveguide.
                Thank you,
                David.
                  • 28568
                  I guess, the minimum is 1600 WITH the waveguide. But it depends on the acoustic phase Tweeter-Midrange, so you have to caculate, whats the best compromise with boxsim 2.0.
                  The Studio 2 sounds very well, esp. with a subwoofer. The Vimo is cheeper and bigger, also a fine speaker.
                  Zuletzt geändert von walwal; 27.07.2019, 08:37.
                    strahlen beide waweguide identisch hab ?
                    in boxsim ist der runde wg oder ?
                      Ja, die strahlen identisch ab
                        • 28568
                        Test in Hobby Hifi:
                        https://www.hifisound.de/out/media/p...dv5Q%3D%3D.pdf
                        • LANDO
                          • 10.12.2004
                          • 2186
                          Etwas später , aber immer gut :-)
                          Musikzimmer:
                          Hörzimmer mit Solitude
                          Reckhorn A 404
