Arta
  • ente
    • 02.02.2004
    • 563
    Original geschrieben von Boxenwastl als Antwort auf einen Beitrag von Farad
    Was soll das? Du teilst uns mit, dass das Einspeisen einer Mikrofonkorrektur in Ivos Programm nicht sinnvoll sei?
    Auf das warten aber gerade viele Benutzer dieser Software.
    Interessantes Statement auf der SmaartLive-Seite:
    Q: Can SmaartLive compensate for irregularities in the frequency response of inexpensive microphones?
    A: The short answer is "no." We recommend that you use a very flat, well-behaved, omnidirectional microphone when performing measurements with Smaart Pro. There are several on the market for under $600 (USD).
    The long answer is that while it would be a fairly easy to do simple magnitude compensation for single-channel RTA mode measurements, attempts to compensate for microphone response in more complex operations (such as real-time Transfer Function and impulse/delay measurements) would almost certainly introduce more errors than were "corrected." The reason for this is that the "dips and peaks" in the frequency response of lesser quality microphones vary widely with angle (pitch and yaw) and are the result of frequency dependent delays (i.e., phase response problems). To correct for this would require complete complex spherical response data for each microphone on a unit-by-unit basis. And even if the necessary data were available, the sheer number of calculations you would need to perform in real time would require much more processing power than PCs can now provide.
    • herbert1
      • 19.12.2005
      • 74
      Vielen Dank. Das war der Fehler. Als Referenz Resistor war der Wert von 100 eingetragen. Dadurch wurden alle Messungen um dein Faktor 10 falsch angezeigt.
      Das alles müsste im Handbuch besser beschrieben werden. Vielleicht kommt das in der Endversion des Programmes.
        tiki
        Guten Morgen,
        The long answer is...
        Hihi, kann ich meinen Kaufrausch bei den Gefell-Kapseln wohl im Nachhinein doch noch rechtfertigen?
        Gruß, der Konsument
        • ente
          • 02.02.2004
          • 563
          @ Tiki
          Microtech Gefell muss man nicht rechtfertigen (wenn überhaupt, dann vor der obersten Heeresleitung!)
          @ alle Elektrischen
          Anscheinend macht die Verdrahtung des Messaufbaues vielen Messeinsteigern Probleme.
          Könnte man nicht den Wunsch "Mini-Endstufe für Messbox gesucht" mit dem Wallin JIG (http://mysite.verizon.net/tammie_eri...jig2/jig2.html) kombinieren? Dann sollte das Thema aus der Welt sein.
          Wer opfert sich? Tiki, Frankynstone, ......
          Heinrich
          • sinus
            • 20.10.2002
            • 1002
            Am Besten gleich mit mikrovorverstärker und alle restlichen sachen auch noch drauf
              tiki
              Könnte man nicht den Wunsch "Mini-Endstufe für Messbox gesucht" mit dem Wallin JIG ... kombinieren?
              Gute Idee! Auf- bzw. Abbauen dauert bei mir auch immer eine gute halbe Stunde (kein extra Meßzimmerchen). So eine Meßbox hinzuwursteln, schaffe ich aber momentan nicht, würde eher kaufen (zuviel unfertige Projekte). Deshalb riete ich auch zu einer möglichst einfachen Variante mit fertigem Leistungsverstärkermodul.
              Mikro-VV-Anregungen gibt es im Nachbarforum unter den Elektronikprojekten. Richi44 ist dort z.B. ein sehr kompetenter Ansprechpartner.
              Gruß, Timo
              Achso, noch etwas:
              Kann man Arta Kommandozeilenbedienung oder anderweitige Befehlssteuerung beibiegen, um verschiedene Messungen, wie z.B. Rundstrahlverhalten zu automatisieren? Wenn es schon genannt wurde oder ich es bloß übersehen habe, bitte ignorieren. Danke!
                Hallo tthorsten,
                Du wurdest schon einmal gebeten, hier keine Links auf Mitbewerberfirmen zu setzen.
                Ist das so schwer zu verstehen für Dich?!
                  tthorsten,
                  ich denke, es gibt immer Spielregeln...
                  Daran sollte man sich auch halten, besonders wenn man schon mal darum gebeten wurde...Wir sind hier nun mal im VISATON-Forum und nicht in einem Herstellerunabhängigen Forum.
                  • sinus
                    • 20.10.2002
                    • 1002
                    Vifa gibts sowieso nichtmehr also läuft das ausser Konkurenz
                    • Boxenwastl
                      • 29.12.2005
                      • 501
                      Wenn Visaton Verstärkerbausteine erzeugen oder vertreiben würde, wäre die Werbung für das Modul eines anderen Herstellers in diesem Forum unangemessen.
                      Muss man für unser Hobby Geräte ausländischer Hersteller verwenden und den deutschen Geschäftsmann in unserer Heimat, bei gleicher Qualität links liegen lassen?
                      Aber da das nicht der Fall ist und Visaton nur !!! Lautsprecher herstellt, kann man doch in einem Link auf den deutschen Vifa-Generalvertrieb verweisen, dessen Chef, Hr. Gerd Lommersum, ein ausgewiesener Lautsprecherspezialist ist, der auch Messkurse zum Thema Hobbybox anbietet.
                      Zudem ist Hr. Lommersum ein ausgesprochen hilfreicher, sympatischer, ehrlicher Mensch und Geschäftsmann, bei dem man sehr gut beraten wird und der einem nur das verkauft, was man wirklich braucht. Das ist leider nicht bei allen Händlern der Fall.
                      Das nur zur Klarstellung, bevor über den deutschen Vifa-Vertrieb und dessen Geschäftsführer hergefallen wird.
                        Original geschrieben von tthorsten
                        ...also manchmal echt
                        Eben tthorsten, eben!
                        Du bist darauf schon mehrmals explizit angesprochen worden. Und
                        "... also manchmal echt..." könnte man sich schon alleine aus Höfflichkeit danach richten.
                        Ich gehe davon aus, dass auch Friedemann nichts dagegen hätte, wenn es in dieser Form geschehen würde:
                        Lautsprecher - Messtechnik (damit bliebe dem interessirten Leser auch das Herumgeklicke auf der besagten Seite erspart).
                        Denn sonst könnte man bei Vifa auch einen Link auf www.visaton.de anbringen und sagen, dass man dort Holzschrauben finden kann.
                        Abgesehen davon nehme ich an, dass es kein Zufall ist, wenn jemand seine Seite so gestaltet, dass sich dort so gut wie nichts direkt verlinken lässt (im Unterschied zu der Visaton Seite!) Hier heisst es immer soundso.de Man ist zwangsläufig darauf angewiesen, ganz oben einzusteigen und alles durchsuchen, bis das richtige gefuden ist.
                        Dies ist auch schon angesprochen worden. Ohne dass tthorsten in irgendeiner Form darauf reagierte.
                        Messtechnik hin, Lautsprecher her.
                        Zuletzt geändert von harry_m; 27.03.2006, 13:03.
                        • sinus
                          • 20.10.2002
                          • 1002
                          grummelgrummel...um mal zum Thema Arta zurückzukommen:
                          es wäre doch recht nützlich noch ein kleines Feature bei der Impadanzmessung einzubinden.
                          Mit dem Messaufbau der Impedanzmessung müsste man doch noch recht einfach eine Induktion- und Kappa-messung programmieren können (-3dBPunkt). Vor allem Spulen ausmessen zu können wäre doch ein nettes Gadget um sie ev komplett selberzuwickeln oder bei bedarf eine Vorhandene zum gewünschten Wert abwickeln.
                          Chris
                          • Boxenwastl
                            • 29.12.2005
                            • 501
                            Wunderbare Idee.
                            Und somit wären wir schon wieder einen Schritt näher bei Clio und ähnlichen Zeitgenossen.
                            • ente
                              • 02.02.2004
                              • 563
                              ARTA
                              @ tiki
                              Steht meines Wissens bereits auf dem Zettel.
                              @ sinus
                              siehe hier http://www.hifi-selbstbau.de/text.php?id=113&s=read
                              ..... und bzgl. grummelgrummel gebe ich dir Recht. Einiges könnte man sich bequem ersparen.
                              @boxenwastel
                              ..... könnte auch schon ein Schritt mehr sein.
                              Heinrich
                              Zuletzt geändert von ente; 28.03.2006, 00:40.
                                Sind denn die zwei Wochen, die es noch bis zum Erscheinen der neuen Verson zu warten galt schon verstrichen?
                                Oder gibt es etwas Neues bezüglich des Erscheinungstermins?
                                Auf der ARTA Homepage ist noch nichts zu sehen.
