First Development version of Boxsim in english language
  • mcl2k6
    • 26.11.2018
    • 19
    Zitat von UweG
    Not in this thread. This one is for the english version of Boxsim.
    Please open a new thread and maybe attach the project file because frequency response is not the only interesting topic.
    Did it: http://forum.visaton.de/showthread.p...449#post451449
    Thank you!
    • Willy_65
      • 13.12.2018
      • 77
      #47
      I am optimizing the Couplet Light for use with tube amplifiers. So a better impedance curve is a priority.
      I achieved all that, including a better acoustic power response.
      Therefore I also had to use the dome tweeter G 25 FFL.
      Now I get a frequency response with @ 6dB = 47Hz- @ 10dB = 36Hz-30kHz.
      To achieve an even better spread for the tweeter I will use the waveguide WG 148 R, for which I have to adjust the height of the box from 46 to 52 cm.
      My question now is: Is it sufficient that I select in "enclosure and baffle / baffle and position" under "shape of diaphragma" Waveguide and nothing else?
      I use the option "Common outer housing"
      I don't see any difference under "Frequency response".
        • 1265
        #48
        Hi Willy
        All tweeter with WG´s have a different set of data for boxsim - you have to exchange them.
        Boxsim -> Chassis: select your tweeter (G25FFL) -> load from file -> G25FFL-8_WG.BCH
        Thats it - as far as I know
        • Willy_65
          • 13.12.2018
          • 77
          #49
          Zitat von goofy_ac
          Hi Willy
          Now I understand why I often see WG tweeters in use but not for sale
          That will certainly be the solution, thanks for the quick response !!
            • 1265
            #50
            You´re welcome - it´s seldom enough that I as a youngster can give some advice
