[Searching] Center W-T-W
  • CCJENS
    • 17.08.2004
    • 21
    Hi, i am searching a center, i want to use the w130sc 4 ohm and the g20sc 8 ohm in it...
    2x W130SC/4
    1x G20SC/8
    Does somebody know a nice design?
  • Jorge
    • 16.02.2003
    • 1507
    Are you using the Basic Monitor as fronts? Why not using a additional basic monitor as center?
    Grüße Jorge
    • CCJENS
      • 17.08.2004
      • 21
      I have mini-monitor basic as rears...
      BUt i want a real center ...
      woofer - tweeter - woofer..
      • Jorge
        • 16.02.2003
        • 1507
        OK, but are only speakers with w-t-w real center speaker? Should they work as 2 or 2,5 way speaker? I guess also that you want to lay down the center, dont you? That's not a good idea with d'appolito like speakers... Maybe the Couplet light is what you're searching for...
        Grüße Jorge
        • Tosti
          • 21.10.2002
          • 846
          if you want a REAL center, then build another Basic Monitor! That's by far the best center for you!!!
          Greets
          Tosti
          • CCJENS
            • 17.08.2004
            • 21
            Hmm okay, but i want 2 woofers and 1 tweeter, i think its looks nicer, and better 4 a center..
            Only 4 ohm pls..
            • MrWoofa
              • 22.09.2001
              • 4765
              Important is, what sounds better, and that is a Center which is exactly the Box u use as mains.
